KEBC troubleshooting help
Old Oct 5, 2003 | 06:14 PM
MDG's Avatar
MDG
Default KEBC troubleshooting help
My KEBC and 4wd is not working. I checked the fuses under the seat and they are OK. Is the KEBC fuse in a different location? Before this happened there was a knock coming from the Primary. I assumed it was the wear shoes. Now the knock has gone away as well.
Other then 4wd and KEBC everything seems to be working fine.
Belt is tight.
Black spring only.
No power loss.
If the KEBC actuator is out would that stop the 4wd from working too?
Looking for some suggestions from the experts.
Thanks Guys
Martin
Old Oct 5, 2003 | 11:13 PM
MDG's Avatar
MDG
btt
Old Oct 6, 2003 | 11:20 AM
MDG's Avatar
MDG
I know someone has had this problem before.
I can't beleive that if the KEBC actuator goes out that the 4wd won't work either.
Anybody have any suggestions or insite?
Old Oct 6, 2003 | 06:35 PM
MDG's Avatar
MDG
Anybody
Old Oct 6, 2003 | 09:14 PM
MDG's Avatar
MDG
Well thanks for the help. Wait a minute, no one helped. Anyway I figured it out. It was the fuse. It did not look bad but I used a meter to check it. Oh well, lost sleep for nothing.
Tip- You can't always just look at the fuse too tell it is broke. Maybe this will save someone some sleep.
pgamboa
Dec 24, 2023 11:52 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
