popping when i release the throttle
Old Oct 5, 2003 | 10:34 PM
BOMBARIDER's Avatar
Default popping when i release the throttle
does anyone know why my bike pops when i release the gas to shift gears or come to a stop? it's stock with a billet end cap it runs good except for this pop. it hasn't been jetted yet. i ride at about 5000 feet. can anyone help?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 5, 2003 | 10:52 PM
dunesled's Avatar
Adjust your air mixture screw on the bottom of the carb. You may be running too rich at that elavation.
Old Oct 5, 2003 | 11:11 PM
RoughRider01's Avatar
Is this correct.. the higher you go the richer youll be running (elevation wise)?? If it pops, it means you are running lean. You should try to richen you air/fuel.. wouldnt hurt to richen up your main jet either.
RoughRider01
Old Oct 5, 2003 | 11:34 PM
Also, i have the billet end cap and got my jets from rockymountain. I ordered the k&n jets, but there really the dynojet ones, you get the needle and tons of main jets. I forget what clip im using with their needle but im using the DJ 190. Probably not what you want for your elevation. Mines alittle rich in the summer but perfect when the temps get lower. Its about 45 degrees F right now and it runs really strong. The instruction tell you what you should use for your elevation.
RoughRider01
Old Oct 6, 2003 | 12:00 AM
dunesled's Avatar
What Roughrider said[img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 6, 2003 | 06:35 PM
cop's Avatar
cop
Ron Wood recomends a 180 main when fooling with the exhuast.
Old Oct 6, 2003 | 08:05 PM
ironrod's Avatar
Yes, a little too lean. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 6, 2003 | 11:09 PM
SANDMAN430's Avatar
i was also thinking lean
Old Oct 6, 2003 | 11:25 PM
1BigDSRider's Avatar
Another thing you may want to check is, make sure the pipe bolts holding it to the engine havent backed out some. Mine worked there way out and I started having the poping on deacceleration. Just retighten if they have backed out.
2quiker
Mar 22, 2022 08:36 PM
slowgsxr97
Mar 18, 2022 03:40 AM
fordfaithful21
Dec 7, 2015 05:52 PM
sleepyva
Sep 2, 2015 06:32 PM
