Vforce carb slides
Old Oct 7, 2003 | 12:51 AM
VforceRage's Avatar
Default Vforce carb slides
I was cleaning my air cleaner last night. I checked the slide movement with my finger and found the front carb slide only opening half way ! The spring inside the carb was not seated in the slide properly. I had put Dynojet needles in two months ago. Funny thing is, the V was running great. Now it runs even better. If you have adjusted your needles, check your slides the next time your in the airbox.
Just a thought[img]i/expressions/face-icon-small-blush.gif[/img] Rage
Old Oct 7, 2003 | 01:41 AM
Mudfoot's Avatar
Man, my rear slide return spring was actually broken in two places, I now own 4 extras because that incident prevented me from going to Hollister a few weeks back. Funny thing was my V was running pretty good too, just a little cough at very low throttle. Those springs are cheap to buy so I figured I'd get a few.
Old Oct 7, 2003 | 11:49 AM
RocketJoe's Avatar
Mudfoot,
Do you have a part number for that spring? I can not fine it on Kawis part diagram. V Force Parts
Thanks
RJ
Old Oct 7, 2003 | 09:55 PM
Mudfoot's Avatar
Part number is # 92145-1227
Old Oct 7, 2003 | 11:13 PM
RocketJoe's Avatar
Mudfoot,
Thanks...
If you need any help with "Dial-a-Jet kit "still " in the box" let me know.
How do you like the HMFDuals?
RJ
Old Oct 8, 2003 | 01:48 AM
Mudfoot's Avatar
I like the HMF duals, they gave me a good increase in power; not as pretty as the Yosh. but they work well. I would recommend them to anyone, just get the "quiet cores" they're worth it. No need for the dial-a-jet, running perfect from bottom to top. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 5, 2003 | 10:19 AM
Strokem's Avatar
What setting do you have your Dial-Jets-On for the HMF Dual and do you have the TPI Vents
Old Dec 5, 2003 | 10:26 AM
Strokem's Avatar
Also what did the Spacers do for you? Give you a wider stance?
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
