Faster Raptor for cheap
Old Oct 7, 2003 | 10:35 PM
Raptorkid25's Avatar
Default Faster Raptor for cheap
What r some cheap things u can do to make ur Raptor haul a$$..I already have FMF Megamax slipon..Friend has YFZ and wants to drag race i wanna be able to beat him
Old Oct 7, 2003 | 10:36 PM
caliraptor's Avatar
You probably wont beat him, but get a 12 tooth sprocket, it will help
Old Oct 7, 2003 | 10:39 PM
Well i do alot of trail riding will a 12 tooth sprocket affect that??Is that a 12 tooth on front or back?
Old Oct 7, 2003 | 10:46 PM
caliraptor's Avatar
Front...you will get more low-end power, but will probably lose 3-5mph on ur top speed. Shoudl help u out for trai riding, but will probably have to shift quicker, since 1-2 shift goes by real fast.
Old Oct 7, 2003 | 11:00 PM
UBETRUN's Avatar
Remove your airbox lid and get a K&N, don't oil it too much. Make sure your carbs are properly adjusted and jetted. Drop a tooth in front and practice launching in 2nd. Play with your rear tire pressure and rear shock preload. Find a balance between spinning too much and not enough, you want it to hook up but not hard until you are in the power. You may have to sit way forward and slide back as the front end settles. Shift as soon as it stops pulling hard, or right before if you are good. That's my strategy, we'll see if it works next weekend:-)
Old Oct 8, 2003 | 06:53 PM
What size filter do u get? What do u just take the big black lid off under the seat? Can u do that w/out changing to a K&N?
Old Oct 8, 2003 | 07:01 PM
Starky's Avatar
No, you have to get an adaptor and either a foam or K & N filter. If you take the lid off you are going to have to rejet. It may run ok without the new jets, but once you do rejet you won't believe the power you gain.
Old Oct 8, 2003 | 07:03 PM
Mr45auto's Avatar
The filter is made for the Raptor. You should not remove the lid, yes the black lid under the seat. If you remove the lid completely you will allow your filter to lose it's seal and allow crap into your intake. Of course if you get the pro flow kit or something similar you can completely do away with the airbox lid. With the stock replacement type K&N you can cut holes into your lid or even cut it up completely while retaining the portion that keeps the filter in place. You will need to rejet your carbs, if you arent confident doing that find a competent mechanically inclinded person and follow the instructions on whichever jet kit you buy. You should have rejetted when putting on your slip on pipe if not you may be harming your engine and running less power than stock. Going out on a limb here I doubt the FMF flows significantly better than stock anyhow, I've never seen a high power Raptor running one. I'd definitely go with the 12tooth front sprocket though and you'll stand a better chance out of the hole. It's all gonna be in who gets the best start.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
01ssls1
Sep 22, 2015 06:50 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
