TRX 250R/CR500 Help Me!
Old Oct 8, 2003 | 04:48 PM
Sparky8's Avatar
Default TRX 250R/CR500 Help Me!
I Have a had several Honda 250R's and loved them all. I have had a couple tricked out bikes and one with a CT310 kit. But I have always wanted one with a CR500 motor. I am considering building one or trying to find one for sale. Has anyone done this before or know someone that has? I am a little concerned about some of the things I have heard about them. I have heard that 250R's with a CR500 motor have a severe vibration. Can anyone tell me if this is true or not. And if it is, what causes it and is there a way to correct it? Any info would be appreciated!
Old Oct 8, 2003 | 04:56 PM
No2StrokeBs's Avatar
You have a forbidden word in your message post. Please click the back button in your browser and remove this word from your post. The words that are forbidden are highlighted for you.
Your only concern would be vibration as the 500 is not counterbalanced. I have seen quads that have CR500s in them and they cannot be gussetted enough to stop breakage. Even when they are reinforced heavly, you cant ride them for more than about 10min without your hands going numb. I would suggest one of the larger cylinder kits for the 250 as they can be made to pump out some serious power. Check this 425 kit out
http://atvscene.com/evaluations/psi-425-r.htm
kinda pricy, but gives you an example of whats out there, also, check the 250/500 hybrid, I think this is the route id take. This is where they modify the lower unit of a 250r to accept a 500 cylinder, ill send you a link as it has a "forbidden" word in it from another fourm, apparently this place is scared of a little competition. What a bunch of BS.
Old Oct 8, 2003 | 06:19 PM
KGB's Avatar
KGB
Don't do it, unless you only want it for a run or two a day. Its a vibrator. There is no way to get the vibration out of it. Parts fall off all day long, frames crack, exhaust mounts break, ect. Sounds fun, but its not.
Old Oct 8, 2003 | 07:16 PM
HA2's Avatar
HA2
A certain fella by the name of cr500 - threewheeler is selling his ATC CR500 R. It's a SWEET trike, nice ext swing arm, all white plastics, and powdercoated frame. might want to look into that.
Old Oct 17, 2003 | 08:14 PM
trx500r's Avatar
Hi,
How do make contact with guy who ones the cr500 trike
Old Oct 18, 2003 | 07:56 PM
trxs2fast4u's Avatar
The trx 500 can be done but it is very exspencive and would be kind of rigged up if u tryed to just throw it together.
Old Oct 18, 2003 | 08:15 PM
RacinJason's Avatar
I've seen them done right...but most the times motor mounts and exhaust systems break and crack after a ride
