Overheating...a little
Old Oct 8, 2003 | 10:24 PM
Endomaniac's Avatar
Default Overheating...a little
My bike is overheating from time to time. Its got plenty of coolant and oil. The fan is running great.
So what is there to do?
On these motors is it like a car where you can get cooler set thermostats or can I just take it out?
Radiator Shrouds?
Need some info here!
Also finally cut the fenders gonna finish them up Friday will have the pics up soon. [img]i/expressions/face-icon-small-happy.gif[/img]
Also got a new grab bar on the way from PRM gonna give them another try. [img]i/expressions/face-icon-small-smile.gif[/img]
Also gonna have some pics of our ride this weekend to.
Thanks Guys
Old Oct 8, 2003 | 10:33 PM
SANDMAN430's Avatar
probably jetted lean
Old Oct 8, 2003 | 10:36 PM
Endomaniac's Avatar
Really .....
Ill have to check that out..... Will having it jetted lean also cause some slow throttle response?
Its not to bad with the air cover on but if I try to take the cover off its has really slow throttle response.
Old Oct 8, 2003 | 10:41 PM
SANDMAN430's Avatar
i don't know what jet kit you have but sounds like you would want a 170-180 stock jet.
Old Oct 8, 2003 | 10:42 PM
Endomaniac's Avatar
I have the K&N Jet kit
Old Oct 9, 2003 | 12:46 AM
DSJOBBER's Avatar
Drain your coolant and mix 50/50 water wetter and h20. Also try adding radiator shrouds and possibly a in-line cooler.
Old Oct 9, 2003 | 03:14 PM
KaiserSosei's Avatar
Mr. Endomaniac, I HAVE HAD MY DS for about 2 years when it started running hot about 2 months ago, ( fan always on, coolant hose on the left side blowing off enough to spray hot coolant on my right leg, red light was comming on etc....) went ahead and changed the thermostat and ..........no more problems. I think the thermostat was sticking???? causing a back pressure that was causing the coolant hose on the right side to partially blow off causing me exetreme pain when hot coolant hit my bare right leg. Go figure-why me Jesus??????
Old Oct 9, 2003 | 04:50 PM
ironrod's Avatar
.... what they said.
Old Oct 9, 2003 | 06:19 PM
Endomaniac's Avatar
Kaiser.... thats exactly what mine has been doing!!!
Thanks for the info .... ill check out the t-stat
