Prairie 650 bent axle repair or replace?
Old Oct 9, 2003 | 09:56 AM
BadBrad's Avatar
Default Prairie 650 bent axle repair or replace?
Hey, I got a question I hope someone out there can help me with. I recently bent the axle on a Prairie 650 and need to fix it. I know about the pricing of a new and after market axle, and the striating out that a machine shop can do with the bent one. My question is how hard is it to take apart and put the rear end back together? I saw on another forum some did it and said it wasn't hard and only took about 1 and a half hours but, didn't go into detail as to what you need to do. I am looking for someone to give me a little more on what exactly needs to be taken apart and if there is anything really tricky about the whole operation. If any one can give me some real help on this I would really appreciate it. Thank Brad
Old Oct 9, 2003 | 10:30 AM
nyroc's Avatar
Too cheap to get a repair manual?
rear axle tech tip
Old Oct 9, 2003 | 06:32 PM
BadBrad's Avatar
Thanks for the web site with the info on how to change out the axle. And to respond to your knock about being to cheap to buy a manual.... I was looking for advice on if I should do this repair myself or if I should take it to a Kawasaki dealer. If anyone out there has anyu advice on how hard this is and if there is anything really tricky about it I would really apreceate it. Thanks
Old Oct 9, 2003 | 06:46 PM
nyroc's Avatar
It appears to be an extremely easy procedure. I personally think adjusting the valves is a lot harder.
I am just going from what I read in the repair manual (that I think other people should get). I felt the procedure looked very easy, all except for the torqueing the bearing retaining nut to 188ft lbs. Although I think you use the hubs in a vise to hold the axle while you crank on the nut, though tough part apears to be how to get a torque wrench on the nut. I would just try to estimate that torque.
You may not have to remove the bearing anyway if you just are going to get it straightened.
Old Oct 9, 2003 | 08:30 PM
Danboy's Avatar
You have no choise to fix or replace .Because kawasaki dealer they will not replace .I bent my and my bike is just 4 mouth old . no way they said that i abuse my bike that why i bent my axle [img]i/expressions/face-icon-small-mad.gif[/img]. And they want 700.00 for new one .ha ha I not the first one that bent that %$%%%$ axle . SO no more p650 for me.
Old Oct 9, 2003 | 11:46 PM
PROCHARGER's Avatar
256.00 AT KAWASAKI DEALER. GO AHEAD SELL YOUR P-650
Old Oct 10, 2003 | 03:10 PM
DustinMinnesota's Avatar
Taking the axle out is easy. I would straighten it if it is not too bent. NYROC will tell you if the bend is too bad the metal is fatigued from the bend.
FYI - A VForce Aftermarket axle is the trick I hear but I have not been able to find one to see the difference.
Old Oct 10, 2003 | 09:12 PM
Encore454's Avatar
Alltoys just turned a new axle out of titanium when he needed one...
Wouldn't it be great to be able to do 1/10th of the things he can do to his quad!
Old Oct 10, 2003 | 09:25 PM
QUADMAN650's Avatar
JUST TAKE THE AXLE OUT AND TAKE IT TO A LOCAL MACHINE SHOP THEY CAN PUT IT ON A LATHE AND STRAIGHTEN IT I DID IT TWICE ON MY WARRIOR
Sandman2.0
Jul 21, 2015 09:03 AM
JackTheKing
Jul 14, 2015 09:09 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
Rider252
Jul 6, 2015 03:37 PM
