hmmm, how does oil magically keep reapearing in the tranny if you don't add any?!?!
Old Oct 9, 2003 | 07:40 PM
crispy's Avatar
Default hmmm, how does oil magically keep reapearing in the tranny if you don't add any?!?!
yeah. I run bel ray synthetic injector oil in my blaster, and it's a blue color. well not to long ago oil started to come out of my tranny over flow tube. so i drained some oil out of it, and it ran fine. well then i noticed my oil in my injector tank start to go down faster than normal. i'd run it for 3 hours and be on a half a tank. then oil started coming out of my over flow tube for my tranny again. hmmmm. the injector line running through my transmision must have a leak b/c that could be the only way extra oil keepsgetting in my tranny. how do i know this? because when i drained more oil from the tranny the second time it was the same bright blue color as my injector oil. ! messed up ! I'm blocking off the injector and running premix. just another story about why you should block off the injector.
Old Oct 9, 2003 | 08:09 PM
Hozed's Avatar
the line doesnt run thru yor tranny does it?
the line goes undernearth the sidecover not thru the trannny.
Old Oct 9, 2003 | 09:24 PM
RaptorOwner's Avatar
I dont trust the injectors either, I purchased a JR50 and immediately plugged that puppy up and mixed my own.
Old Oct 11, 2003 | 02:49 AM
Blaster96's Avatar
there should be a seal or something between the pump and the case side. This may have gone bad. You could plug up the injector and run premix, or replace that seal. I am not positive about how that all fits together. i doubt you would have to split the cases to change that seal. Get a service manuel and call it good.
Old Oct 11, 2003 | 09:01 PM
crispy's Avatar
do you think the 2 stroke oil in my tranny hurt anything?
Oct 10, 2015 10:20 AM
Logan Collins
Sep 5, 2015 08:03 PM
Haakon
Aug 24, 2015 01:54 PM
DeFox500
Jul 26, 2015 06:32 PM
mr-tigger84
Jun 29, 2015 05:30 PM
