2002 700 Reverse Overide Bypass
Old Oct 10, 2003 | 01:34 PM
mcman's Avatar
Default 2002 700 Reverse Overide Bypass
I need help on bypassing the overide switch. thanks
Old Oct 13, 2003 | 10:48 AM
firemedic5586's Avatar
I down loaded this awhile back.... The 1st mod has worked great for me, not sure If i'm going to do the second mod.
I can't guarantee this is right for the 02 700, but for the 03 700, the system works by removing the ground from the awd system. you can fix the awd so that it is not affected by the override switch by placing a jumper between brown/white wire and brown wire. The effect of doing this is when you put the "awd" switch in "awd", it will be in awd regardless of what gear you are in. The jumper goes in the headlight pod, both the brn/wht wire and the brn wire hook directly into the speedometer. So you only need a short jumper. Hope this helps
ps. this will not affect the other parts of the override system, just provides awd in reverse. For plowing with my 03 700, i have placed a switch on the headlight pod. when i turn the switch on, i get automatic override when in reverse. I hooked this up with a different jumper, that goes from the purple wire (reverse)to the gry/orange wire. Again, both wires are in the headlight pod and run to the speedo, so it is an easy mod. I used the wiring diagram from the 03 700 to figure this out, I haven't seen the 02.
Old Oct 13, 2003 | 02:51 PM
lovemud's Avatar
I use a rocker switch mounted on my POD, on the 03's or newer the POD display willl freak if it's on too long, not to worry, but I'd use a switch, not just a jumper.
I used the yellow switch on the handlebar for a horn I mounted in the POD and power from the accessory port.
Now I can beep at those Honda's to get out of my way [img]i/expressions/face-icon-small-happy.gif[/img]
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
