egt temps on alky
Old Oct 10, 2003 | 10:56 PM
saint650's Avatar
Default egt temps on alky
i just swapped out my air/fuel guage for an egt. i am also switching over to alky. what should my egt be around. whats to lean and to rich temp wise? and tunning tips with an egt and alky
Old Oct 10, 2003 | 11:48 PM
DuneDevil's Avatar
On the EGT's, it will depend on how far away the probe is from the piston.
I have been told that if the probe is 4 to 6 inches away from the piston, you don't want to see temps over 1200 degrees.
DuneDevil
Old Oct 11, 2003 | 01:53 AM
ThePunisher's Avatar
Dune Devil is correct. Put the probe about 4" away from the head. You want to run at wide open throttle at about 1250 to 1280 degree's. Your piston starts it's melting point at 1300 degree's. This is the best way to tune in a 2-stroke and I haven't figured out why I haven't done it yet?![img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 11, 2003 | 04:32 AM
Sandragggen's Avatar
Which pipe do you put the egt sensor in at 4" from the exhaust manifold?
Old Oct 11, 2003 | 07:51 AM
saint650's Avatar
I HAVE AN O2 BUNG ALREADY IN THE PIPE WHERE THE TWO FRONT PIPES COME TOGETHER. I TOOK A BUNG PLUG AND DRILLED THE MIDDLE FOR THE EGT PROBE. SO THE PROBE IS PROBALLY 12 INCHES FROM THE PISTON. WILL THIS STILL WORK?
Old Oct 11, 2003 | 10:39 AM
sixsixT's Avatar
No the probe needs to be at the tip of the exhaust flame. The closer to the tip of the flame the more accurate the reading.
Old Oct 12, 2003 | 08:15 AM
saint650's Avatar
OK MY EGT NEEDS TO BE RMOUNTED. SO IF I HAVE TO MOUNT IT 4IN FROM THE CYLINDER, DOES IT MATTER WHICH ONE I MOUNT IT TO?
Old Oct 12, 2003 | 10:16 AM
sixsixT's Avatar
It shouln't matter.
Old Oct 14, 2003 | 05:04 AM
saint650's Avatar
what should temps be at idLE and half throttle, still the same at 1250 or so or will they be lower?
Old Oct 14, 2003 | 04:27 PM
They should be around 1000 at idle or so. Just jet accordingly to the condition. You want to run cooler at idle an then drive around half throttle and watch it. Like I said you want those temps to be as close to 1300 with out going over. You want to stay between 1200 and 1300 from off-idle all the way to full throttle.
