Toe setting, when caster is corrected?
I know that the recommended toe on this board is between 1/8" toe-out and 0", for stock a-arms. The toe-out is to compensate for the lack of caster angle. What would I want to set my toe at, now that I have new upper a-arms and will set the caster correct?
Thanks!
Thanks!
Thanks!
Thanks!
Thanks for your reply, but unfortunately I did not recieve until now. I had a time setup with my brother to align my DS this morning. I was luck enough to be able to use an alignment machine. We turned out adjusting the toe at 1/8" toe-in. I will give this a try for starters. Thanks again.
Elkaholic
Sep 6, 2015 02:44 PM
