Toe setting, when caster is corrected?
Old Oct 11, 2003 | 01:47 AM
DeanB's Avatar
Default Toe setting, when caster is corrected?
I know that the recommended toe on this board is between 1/8" toe-out and 0", for stock a-arms. The toe-out is to compensate for the lack of caster angle. What would I want to set my toe at, now that I have new upper a-arms and will set the caster correct?
Thanks!
Old Oct 11, 2003 | 11:30 AM
BigWaynester's Avatar
Thanks!
Stick with the same setting, it worked for me...but there may be a better setting.
Old Oct 11, 2003 | 05:19 PM
DeanB's Avatar
Thanks for your reply, but unfortunately I did not recieve until now. I had a time setup with my brother to align my DS this morning. I was luck enough to be able to use an alignment machine. We turned out adjusting the toe at 1/8" toe-in. I will give this a try for starters. Thanks again.
bvolks
Sep 13, 2015 12:57 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
Elkaholic
Sep 6, 2015 02:44 PM
DGNAZ
Sep 5, 2015 09:14 PM
Brandon400
Sep 5, 2015 08:44 PM
