Clutch saftey switch
I am having troubles with the clutch saftey feature on my Raptor. There is not much play at all with the clutch lever but I have to pump the clutch in and squeeze really hard to get it to turn over. Is ther a way to adjust the sensitivity on this or could it just be dirty. Anyone know how it works. I am going to take it apart but I would like to know what might be getting into.
You probably have some grease or grime build up on the plunger of the sensor. Take it out of the perch by pushing down on the tang in the perch that locks the sensor in. then clean it with some kinda degreaser.
You can also disconnect it down under the radiator byt unplugging the two connectors and plugging the two ends from the bike together, then it will start in any gear at any time wether the clutch is in or not, not good for the starter one-way
