440: first ride..
Old Oct 14, 2003 | 06:43 PM
whatwasthat's Avatar
Default 440: first ride..
well, i finally broke in the new 440, i Have a weisco 11:1, hot cams stg 2 and a k&n filter. I am a little unimpresssed with the power gains, however, keep in mind that i am running the stock pipe. I ended up going with the stock pilot, d/j needle on the 3rd clip and a d/j main at 160. The motor does pull harder with no bogs or hesitations, but like i said, i expected more. I am wondering if i could jet a little leaner?I havent done a plug check yet either. The motor ran unusually cool compared to the horror stories i have heard from 440's overheating, and i am on the stock oil system/cooler. What little tricks could i do to eek a little more out of the engine without getting a new pipe?
Old Oct 14, 2003 | 07:26 PM
HA2's Avatar
HA2
i wouldnt even make any kind of an opinion of the 440 until you put an aftermarket exhuast on it.
Old Oct 14, 2003 | 07:45 PM
hondatv's Avatar
I would install a black box. I noticed a slight difference when I installed my box. A pipe will wake that kit right up, makes a big difference. Just my .02 /:-)
Old Oct 14, 2003 | 07:50 PM
KGB's Avatar
KGB
HA2 is right, if it restricts the stock motor, imagine what it does when you pump it up.........I think there is a mod I have seen for a stock pipe, sorry I don't know where, but I imagine you could get it from that other site that deals w/ honda ex's.
Why no pipe? Money or Noise? if its money look into the above, if its noise look up MBRP.
Old Oct 14, 2003 | 08:08 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
First thing to do is to pipe it so it has less restriction. I would try running a 155 main, thats what i run and mine never has over heated. The temperature where ever your from can make a big difference on the jetting.
Old Oct 14, 2003 | 09:01 PM
SANDMAN430's Avatar
appears a bigger carb might be the answer.
Old Oct 14, 2003 | 09:42 PM
mxquadracer's Avatar
you basically have to get a better pipe the stocker sucks and it will give huge hp gains with the 440 kit.
vinrum
11
Aug 26, 2015 06:44 AM
RideHonda01
Aug 31, 2003 03:24 AM
Mar 4, 2003 11:42 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
