99 warrior won't start
I am new to the forum and also just got the warrior. I have had plenty of dirt bikes but this is the first fourwheeler. I just got it and drove it on the trailer and started fine but when I got it home it wouldnt start. It was raining a lil when i picked it up. Now when you get on it to start it with it in neutral key on and go to hit the start button it won't make a sound. The dealer said they had just put new battery and starter relay on it since this was a common problem with theses quads. Was wondering if maybe someone had had this experience before or could tell me where to start looking to see if something might be wet or triped maybe a circuit breaker if it has one. any help would be appreciated.
Kevin
Kevin
if the lil green light for nuetral comes on, you got battery juice. There are a bunch of relays and plugs under the left rear fender, pull em apart, get all the dirt out, and put em back together. If thats not enough do the ones under the front hood. Nearly always clears up starting problems. I usually squirt some electrical grease in mine too.
I got it started after playing with some of the connections. I think i m gonna go ahead and take them all apart and spray some electrical grease in there as jakal mentioned to help prevent future problems. thanks for all the help.
