99 warrior won't start
Old Oct 15, 2003 | 02:11 AM
jpwarrior's Avatar
Default 99 warrior won't start
I am new to the forum and also just got the warrior. I have had plenty of dirt bikes but this is the first fourwheeler. I just got it and drove it on the trailer and started fine but when I got it home it wouldnt start. It was raining a lil when i picked it up. Now when you get on it to start it with it in neutral key on and go to hit the start button it won't make a sound. The dealer said they had just put new battery and starter relay on it since this was a common problem with theses quads. Was wondering if maybe someone had had this experience before or could tell me where to start looking to see if something might be wet or triped maybe a circuit breaker if it has one. any help would be appreciated.
Kevin
Old Oct 15, 2003 | 03:52 AM
Crotts's Avatar
There is a fuse under the left back fender by the starter relay, check that.
Old Oct 15, 2003 | 10:40 AM
jpwarrior's Avatar
thanks i'll give that a try.
Old Oct 15, 2003 | 11:49 AM
JakalWarrior's Avatar
if the lil green light for nuetral comes on, you got battery juice. There are a bunch of relays and plugs under the left rear fender, pull em apart, get all the dirt out, and put em back together. If thats not enough do the ones under the front hood. Nearly always clears up starting problems. I usually squirt some electrical grease in mine too.
Old Oct 15, 2003 | 01:04 PM
jpwarrior's Avatar
I got it started after playing with some of the connections. I think i m gonna go ahead and take them all apart and spray some electrical grease in there as jakal mentioned to help prevent future problems. thanks for all the help.
Old Oct 15, 2003 | 09:49 PM
OneWheelWheelie's Avatar
are you canadian
Old Oct 16, 2003 | 10:37 AM
jpwarrior's Avatar
Im from NC
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
