inside out..
if i put my front tires on with the inside out, i get a wider front end. should i see a better turning quad? is this hard on the front rims? i guess i will found out if the tires handle bad with the rotation the wrong way. i know that air stem clears the brake caliper.
Leverage. The wheel axis are placed farther out from the spindle(which gives you the wider stance). This puts more pressure on the ball joints and wheelbearings.
Originally posted by: Slowride
raptor guys do this all the time. It can't be no harder on the ball joints than throwing on a spacer.
jbt
jbt
