inside out..
Old Oct 15, 2003 | 04:20 PM
javex's Avatar
Default inside out..
if i put my front tires on with the inside out, i get a wider front end. should i see a better turning quad? is this hard on the front rims? i guess i will found out if the tires handle bad with the rotation the wrong way. i know that air stem clears the brake caliper.
Old Oct 15, 2003 | 04:22 PM
95Wolverine's Avatar
you can get the tire rotation to be correct by swiching sides on the bike.. still leave them inside out, but switch sides.
Ride on.
Old Oct 15, 2003 | 04:26 PM
javex's Avatar
damn..didn't think about that 1 much..
Old Oct 15, 2003 | 09:28 PM
marrtoo's Avatar
If the valve stem is on the narrower side of the rim, it will hit the brakes.
Old Oct 15, 2003 | 09:30 PM
dsracer666's Avatar
it will put a lot of stress on your balljoints!
Old Oct 15, 2003 | 09:42 PM
javex's Avatar
the valve stem doesn't hit the caliper or rotor, it clears everything. why is it harder on the ball joints than normal setup?
Old Oct 15, 2003 | 09:50 PM
Birdoprey's Avatar
Leverage. The wheel axis are placed farther out from the spindle(which gives you the wider stance). This puts more pressure on the ball joints and wheelbearings.
Old Oct 15, 2003 | 10:14 PM
Slowride's Avatar
raptor guys do this all the time. It can't be no harder on the ball joints than throwing on a spacer.
jbt
Old Oct 15, 2003 | 10:19 PM
dsracer666's Avatar
front spacers are bad too! go for it just keep an eye on it!
Old Oct 15, 2003 | 10:26 PM
Birdoprey's Avatar
jbt
You are 100% correct. They would put the same pressure if spaced the same. The ball joints/wheel bearings may be able to handle the xtra stress, i dunno(alot of people do it). Fact is, there is more stress there...
