Kawasaki Prarie
Old Feb 1, 2000 | 12:35 AM
Havetohunt's Avatar
I just changed the oil in my 2000 Prarie 300. At idle, I notice a slight grinding sound coming from the pull start case. Is this normal? I used 10w-40 oil. Any suggestions on a certain type of oil I should use?
Old Feb 1, 2000 | 09:31 PM
mikeyb's Avatar
I have a 99 Prairie 300 and I have
not notice a grinding noise coming
from the pull start case. You might
want to check with the Kawasaki dealer.
As for oil I would use a high quality
motor oil designed for motorcycles or
extreme duty. Did the 10w-40 meet this
purpose? Believe it or not, but I use
Shell Rotella-T 15w-40 in my ATVs.
Good luck
MikeyB
Old Feb 2, 2000 | 08:07 PM
DaveC's Avatar
I hope ya'll bought the extended warranty. My dad has a 1999 300 Prarie 4x4 that was making the same noise from around the pull start area plus an added rattle when driving. The dealer replaced a bearing on the pull start side of the engine. I think it delt with the either the pull start itself or the crank shaft bearing on the left side. He got it back after one week and it was covered under warranty.
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
shimanok2
Jan 29, 2016 07:37 PM
wendal
Sep 15, 2015 01:50 PM
