clutch slip hot cool down no slip ?
Old Oct 15, 2003 | 09:45 PM
trailride's Avatar
Default clutch slip hot cool down no slip ?
i thought i needed a new clutch the other night we rode it alot and hard and the clutch started slipping but today i go out there to see and it works fine . Ifound it needed adjustment and a new cable . do you think i should go ahead and change the clutch or just leave it alone . i dont want it to get hot again and start slipping at the dunes.87 warriordg pipe
Old Oct 15, 2003 | 09:51 PM
Raptor58's Avatar
Clutches usally only slip when the are hot.
Old Oct 15, 2003 | 09:56 PM
trailride's Avatar
so i should just leave it be.?
Old Oct 15, 2003 | 10:07 PM
UBETRUN's Avatar
I have a Hinson basket and GYT-R clutches on a 686 Raptor. After it's good and hot, I adjust the lever until I can just barely shift into Neutral while the engine is running and it doesn't slip. If I adjust it the same way on a cold engine, it will barely slip at high RPM in 2nd and 3rd after it gets hot. A quick-adjust clutch housing is a great upgrade and not much money.
ghost civic
Jan 15, 2020 07:43 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
clsharky
Jul 13, 2015 02:07 PM
