1996 Scrambler Hub
Old Oct 16, 2003 | 01:37 AM
savage21's Avatar
Default 1996 Scrambler Hub
I Have a 400 4x4 and i need/want do replace the seal, around it on the like what the hub hit when you put it back on , it looks like a liquid blue gasket, but what should i use to replace it with
Old Oct 16, 2003 | 01:54 AM
BigBadScrambler's Avatar
Are you talking about the seal on the rear of the hub, next to the rotor? If that is the one, then you need to buy it from the dealer cuz it is a big seal and not just the gooey stuff
Old Oct 16, 2003 | 01:57 AM
savage21's Avatar
i derno, i jsut put a new cv joint and boot on and fil the hub went on a 5 minute ride and oil was everywhere
Old Oct 16, 2003 | 01:59 AM
savage21's Avatar
where i'm talking bout where i think it is coming out, {remeber i'm not sure where it is jsut know it is} is where the hub slides on the thing that holds the shock tight ordo i need some other kind of seal
Old Oct 16, 2003 | 07:56 PM
pacothemonkey's Avatar
mines doing the same thing but not quite as bad as you describe. i'll refer you to a post that helped me out. here it is. its at the bottom.
Old Oct 16, 2003 | 08:00 PM
There is only 2 seals on the hub, the o-ring seal on the cap and the big seal next to the brake rotor. When I replaced my cv joints I had that same problem. My seals started leaking. You will have to get them from your dealer. They are $13 a piece. Replace the o-ring seal on the cap too. Those are only $1.75. The seal isn't hard to change. Remove the hub and take off the brake rotor. The bolts have loctite on them and you may have to apply some heat to them. Then appy some heat to the seal and pry it out. Be careful though. You don't want to scratch the hub. Use some brake cleaner to clean the hub really good. Install the new seal with the spring side facing down. Press the seal in, or use a big piece of steel and use a hammer to knock it down. Just make sure it goes in straight and evenly. Put then disc back on. The manual syas to use new OEM polaris bolts. But, I used the old one with blue loctite and torqued to 18ft.lbs
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
chewy78
Sep 8, 2015 10:37 AM
