Parking brake
Old Oct 16, 2003 | 10:16 AM
dueces's Avatar
Default Parking brake
Can someone explain how to take the stock Parking brake off a Raptor? Can you keep the stock clutch perch or do you have to buy aftermarket perch to remove PB.
Thanks
Old Oct 16, 2003 | 10:50 AM
Starky's Avatar
Buy the aftermarket perch ($20 or so) the block off plate should come with it. Then you just disconnect the old perch and install the new one and put the block off plate on your brake caliper. I'm certainly not a mechanic but I did it with no problem. When you disconnect the wires on the perch it will make it so you can't start it in gear. Maybe there is a way to by-pass that, but I see it as a blessing not a problem.
Old Oct 16, 2003 | 04:53 PM
quadneck's Avatar
You can just by the block off and still use your stock perch. You purch will still have the spot to connect the parking break and the spot for the safety switch, but it will work.
Old Oct 17, 2003 | 09:58 AM
NotuRaptor2's Avatar
Buy the rear brake perch for a 2000 Yamaha Kodiak. It will allow you to leave the clutch safety switch in place.
If you don't, connect the two wires together and it will start in any gear (just remember to pull the clutch in). You don't want a quad that forces you to find neutral to start. This is too dangerous for the riders behind you who get stuck in a bad situation because you stall and can't find neutral.
Cascade (RockyMountainATV sells them) makes one of the best brake blockoff plates I've seen. It has nice recessed bolts and comes with a rubber o-ring washer. Some of the others like Nacs require factory bolts and silicon sealant to seal it.
/Jon
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Ahtatu
Sep 28, 2015 12:14 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
