Rear Disk Brake Splined Shaft ?
Old Oct 16, 2003 | 01:18 PM
dirtbikejunkie's Avatar
Default Rear Disk Brake Splined Shaft ?
First I really appriciate all the help from everyone on this site! It has been a lot of help!
Again I am working on my brother in law's 92' trailboss 350L 4x4. The brakes don't work on this one either that is the reason he brought it to me in the first place. Anyway I took the rear caliper loose and slid the brake rotor off, the splines on the hub are almost gone. The splines on the shaft coming out of the transmission look a little worn but nothing like the hub. Is this shaft replaceable in the transmission or will it probably be ok if I just replace the hub and rotor? I saw on bigbuckrack.com that they sell a brake upgrade kit for $130.00 that has replacement rotors and pads. Is this kit any good? Any suggestions and help would be greatly appriciated.
Thanks again,
dirtbikejunkie
Old Oct 17, 2003 | 09:51 PM
Honcho's Avatar
dirtbikejunkie:
Normally the shaft is of a harder material than the hub and would require hub replacement only. If it were mine, I would only change the hub. I would only change the shaft once it stripped, why take a tranny apart if it works fine??? you may create more issues than the ones you solve.
...Honcho
STLyamwar
Jul 25, 2020 04:44 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
tporath
Jul 11, 2015 12:31 PM
