34 mm carb on TB
Old Oct 16, 2003 | 06:45 PM
mudmaster250's Avatar
Default 34 mm carb on TB
can any one tell me if a 34 mm carb off of a scrambler or sport 400 work well on my TB 250? its an 2002 if that makes a difference.i am planning on getting the RCR stage one with the top end or midrange kit first or maybe the hpd trail pipe with a standard clutch kit. does any one know what modifications would be needed to make it work and how to do it? i am going to add a UFO if i get it. would i work better than the 35 mm tmx flatslide carb from hotseat? i am sorry about all the questions guys thanks for all of your help, Scott
Old Oct 16, 2003 | 09:06 PM
2manytoys's Avatar
I can personally tell you that the 34mm scrammy carb will work, even with the stock airbox but it will not be nearly as good as the tmx carb from Hotseat. A flatside carb is much more responsive than a roundslide. The 34mm scrammy carb will be hard to tune on the trailblazer because no one really knows the exact jetting. I do know that you have to jet down on the main but everything else will stay the same. Also the HPD trail pipe will be a much better choice for all around performance. This pipe will give you good performance in all the throttle positions. You will like tha gains of the pipe. Good luck!
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
