is 92 p.s.i. compression dangerous in a blaster??
Old Oct 17, 2003 | 06:18 PM
crispy's Avatar
Default is 92 p.s.i. compression dangerous in a blaster??
I've have my blaster for 4 months, my compression is 92. I know i need a rebuild but is 92 ok to ride on for a lil while longer? like 50 hours or so? Or am i endangering something
Old Oct 17, 2003 | 06:32 PM
PatsRaptor's Avatar
If you lose anymore then that your bike will not start because the compression is too low!
Pat
Old Oct 17, 2003 | 06:46 PM
JakalWarrior's Avatar
Dang, you must ride ALOT.
Old Oct 17, 2003 | 07:32 PM
BlackWidow's Avatar
It's not going to hurt it a bit.
Old Oct 17, 2003 | 07:43 PM
87Banshee250sx's Avatar
heh, I dunno if I had a bad gauge or something, but I checked my shee and it was at 65 psi. It still runs amazing too.
Low compression wont hurt, just run 87 octane.
-Nick
Old Oct 17, 2003 | 07:45 PM
RacinJason's Avatar
If thye piston breaks and drops pieces into the crank you will wish you had put the piston in...a loose piston also leads to excessive wear on your cyl...a piston kit shouldn't cost much more than $150 with gaskets and everything...it might just save you money down the road
Old Oct 17, 2003 | 08:01 PM
ALIENraptor's Avatar
I say fix it and sell it, or sell it right now out right. I dont want to see you post any more problems youve had with the blaster[img]i/expressions/face-icon-small-smile.gif[/img] in a good way
Old Oct 17, 2003 | 10:05 PM
crispy's Avatar
it's not like a problem with it, i just don't have about 300$ lying around for a new top end ya know ?!?! do i have any alternatives? can i instead put a wiseco super stock cast piston in it? and that solve my problem?
Old Oct 20, 2003 | 12:42 PM
sAyIt_fmf's Avatar
I blaster piston will run you about 75$ ...the cyclinder cleanup/hone will run you anouther 20 or 30......fix it!!!
hour labor
Scooter's Shop
Oct 9, 2015 02:09 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Steeldon
Sep 9, 2015 09:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
