Grinding when engaging gears
Old Oct 17, 2003 | 06:55 PM
bcbugger's Avatar
Default Grinding when engaging gears
Hi guys,
Just bought a '92 TB 250 (1000 miles on the odo) and I have a problem with grinding when engaging hi/low/reverse when cold. The grinding problem goes away when the bike's warm. I thought it might be cold fluid but it isn't THAT cold. I know the collective mind-trust on this forum should be able to give me a difinitive answer if not an educated guess [img]i/expressions/face-icon-small-smile.gif[/img]
Cheers,
G
Old Oct 17, 2003 | 06:58 PM
95sport400's Avatar
RPM's might be a little high. On the '92, stepping on the foot brake should load the motor down and allow smooth shifting. Give it a try.
Old Oct 17, 2003 | 07:35 PM
MnFriesen's Avatar
yepp...sounds the the rpms are too high when you shift it. that happens to our 99 tb 250 also.
Old Oct 17, 2003 | 08:28 PM
bcbugger's Avatar
Hey thanks for the quick response(s) guys, hopefully that's it [img]i/expressions/face-icon-small-smile.gif[/img] I'll try lowering the idle speed a whisker and see if that's the cause.
Cheers,
G
Old Oct 18, 2003 | 01:02 AM
haskinsguy's Avatar
My 89 TB is the same, just figure it's wear in the clutch, can't get idle low enough to stop it without other problems. So I just tell myself it's an automatic just like newer cars and trucks, you must apply the brake before shifting.
Old Oct 18, 2003 | 10:55 AM
scootergptx's Avatar
Supersock
Hired Gun!
two of mine have done it. lowered the idle speed, and that was it.
Old Oct 18, 2003 | 02:16 PM
bcbugger's Avatar
I haven't poked around it too much yet... been too busy. Easy enough to adjust the idle? I reckon there's just a set screw for idle speed on the carb, or is there more to it? Gotta order the Clymer's for it [img]i/expressions/face-icon-small-smile.gif[/img]
Cheers and thanks to the forum... great guys!
G
Old Oct 18, 2003 | 08:36 PM
bcbugger's Avatar
Just an update to all who were kind enough to answer my question:
Tweaked the idle a bit and presto... no more grinding when cold [img]i/expressions/face-icon-small-smile.gif[/img]
Thanks again guys, VERY much appreciated!!!!!
Cheers,
G
ghost civic
Jan 15, 2020 07:43 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
austinwhitton
Aug 11, 2015 06:21 PM
ghost civic
Jul 15, 2015 10:48 PM
