2001 Sportsman 500ho problem??
Old Oct 17, 2003 | 08:15 PM
lancesamuel's Avatar
Default 2001 Sportsman 500ho problem??
For some reason when i first start up my sportsman there is a load knock coming from engine . This knock has never been there before. After it warms up and is ridden for 5-10 minutes knocking goes away completly until next time I start it again. Any ideas. Do the heads need to be adjusted?? Any info would be great. Thanks
Old Oct 18, 2003 | 10:22 AM
I have also been driving very slow in low gear for last 100 miles or so.. Anyone else have this problem and what was it thanks for any help you can give
Old Oct 18, 2003 | 07:50 PM
IMPORTH8R's Avatar
Can't hear noises over the net, but what you're describing sounds alot like piston slap. This happens when the piston to bore clearance is too great. It will usually shut up when it warms up as you describe. Unto itself it won't really hurt anything, it will just get louder or more frequent as the engine ages. Just about every engine General Motors builds these days has a cold piston knock, if you want a good example of what this sounds like listen to a 00' or newer chevy p/u with the 6.0l. These thing are LOUD when they are cold, some of them even when they are warm.
Old Oct 18, 2003 | 10:29 PM
upnort's Avatar
You did not mention age or miles but yes it does sound like piston slap. With wear of the cylinder the piston will have more clearance but as it warms up things start to expand and decrease the clearance.
Old Oct 19, 2003 | 07:32 AM
Sorry the mach is only 21/2 years old and has just under 1300 miles on it
Old Oct 19, 2003 | 08:06 PM
Traildog's Avatar
Just a thought but maybe it's your automatic decompressor failing to disengage. It engages to start the engine and as soon as the rpm picks up it is supposed to disengage. It can be heard every time you start but after a few seconds knocking disappears. If this is the case I would imagine a loss of power when accelerating.
Like I said just a thought.
Old Oct 20, 2003 | 05:41 PM
hudonl's Avatar
my atv had the same problem i adjusted the idle on the carb and it went away
Old Jun 12, 2004 | 03:32 PM
TheWayOut's Avatar
My 2000 sportsman 500 has been doing the same thing, a noise from the shifter side of the engine, and I also have been using low gear alot, any ideas?
njrider64
Jul 4, 2017 01:40 AM
bikedad3
Jun 29, 2015 08:58 AM
Ringwood
Jun 27, 2015 03:02 PM
DOAinNY
Jun 11, 2015 10:34 PM
UPLou
Jun 7, 2015 09:42 AM
