aftermarket a arms
Old Jun 11, 2000 | 03:07 PM
stevie's Avatar
Does anyone make any after market a arms forthe scramblers because the a arms that are on there are weak. please giveme any info you no.
THANKS
Old Jun 11, 2000 | 07:05 PM
Mike Chero's Avatar
stevie,
Aaen makes a wider version of the A-arms (@ $300 per set), but I don't think this is what you're looking for. Polaris makes the A-arms flimsy to protect the frame. If the frame gets bent, you will have to buy a new quad. So be thankful that they are flimsy.
Old Jun 11, 2000 | 07:31 PM
stevie's Avatar
That is a good point. But if i put longer a arms wouldnt i have to put on longer shafts
Old Jun 12, 2000 | 07:23 AM
Mike Chero's Avatar
Yeah, they supposedly only make them for Sports and 2x4 Scramblers. They are a bit pricy too, considering you can nearly buy 10 stock a-arms for the same $300
Old Jun 16, 2000 | 10:09 PM
Mike Chero's Avatar
Stevie,
I just got my A-arms for the Sport from Aaen, and they do make A-arms for the Scramblers. They are standard length, but are really stout. I think you'd like them, but they are, as I said in another post, a little expensive. Hope this helped!
Old Jun 17, 2000 | 09:32 AM
stevie's Avatar
Do they cost more than 179 per pair because hotseat. Has them now. WHat is the number to aaen
Old Jun 18, 2000 | 07:52 AM
Mike Chero's Avatar
Yeah, they were about $300, but I needed the extra width/strength.
Aaen's # is (262)-552-8981
Old Jun 18, 2000 | 11:55 AM
Lurch77's Avatar
After bending one of my a-arm on my Blazer, I will just be adding a new stock one. But also adding some a-arm gaurds. I just can't afford $300 for a-arms. That $300 is going for an RCR kit.
Old Jun 18, 2000 | 02:25 PM
stevie's Avatar
If that stock a arm cost more than 100 i would buy the hotseat pair for 179 for both ofem
Old Jun 18, 2000 | 10:23 PM
quad_man's Avatar
Don't forget to check your a-arm shaft. Do the aftermarket arms come with the shaft?
The Polaris kit doesn't include the shaft, so dealers usually have to order it seperate.
