440EX horsepower rating
i have a 2001 honda 400ex that im building up to a 440ex with stage 2 hotcam, hotrod connecting rod, k&n filter and jetting, how much horsepower will i make with these mods?
also, how much power does porting add?
Stock hp is about 26-28, I believe. I would say if you did the 440 kit, a cam, and a good port & polish job you could easily get 10+ ponies. I mean they say a stock YFZ is getting 45hp, so you gotta be somewhat close, right?
you won't have the same horsepower as the yfz. i talked to someone with a decked out 440 that couldn't keep up with a stock yfz. he said he had more torque, but that yfz keeps revving and revving and in the higher gears he was left behind by a couple atv lengths. why are you wanting the stage 1 cam? are you wanting this mainly for trails and not speed? you will probally notice a difference with a port/polish if you go to a good engine builder. you would probally notice much more difference if you put on a fcr 39 though. i bet your horsepower will be less than 40.
Maybe torque over a broad range of rpm/s? But torque is not everything or would be using diesels.
The longer you can extend the peak torque range (say maintaining 80% of peak torque) the more useable power you will have. If your torque peaks at say 3700 rpm's but dies off quickly after that say having only 60% of peak at 5500 rpm/s, and someone else reaches a little lower peak torque at say 3600 but maintains up to 80% of this torque up to 6500 rpm's, the second bike will have a lot more useable "power" than the first. The first will require a lot of shifting to stay close to the peak range.
Originally posted by: scrambler420
with the 440 kit you might be pushing what my stock scrambler is pushing,pretty sad huh?
