scrambler rear shock is junk!!
Old Oct 20, 2003 | 07:07 PM
scrambler420's Avatar
Default scrambler rear shock is junk!!
my rear shock is is junk,i keep braking the spring retainer..the one in it now is the third one that broke..
what was polaris thinking when they made the retainer out of aluminum?how many of you have had this problem?i dont want to have to replace it evertime i go out for a day of jumping,so im thinking i should go with a works shock,or is there something better?does the works setup come with their own spring or do i need to use my own?thanks for any input..
Old Oct 20, 2003 | 07:20 PM
NYC's Avatar
NYC
That SUX!!
Sorry to hear that...
Hope you get it FiXed or can get a better retainer..
Well I hope it don't happen w/ mine...
I was hitting some 5'-6' high jumps this past sunday on my 500.
Old Oct 20, 2003 | 07:33 PM
RookWV's Avatar
Haven't had a problem with mine. Maybe you've got it set too stiff? Have you messed with the preload or the reservoir?
Old Oct 20, 2003 | 08:25 PM
IMPORTH8R's Avatar
Mine is the same way and I haven't messed with it either. It hasen't broken yet but it has jumped threads and is crooked under the spring. But I ain't messin' with it till it does break.
Old Oct 20, 2003 | 08:53 PM
i was running the spring kinda tight the first 2 retainers but on this third one the spring was set pretty soft,its about half way down the threads and i weight about 165,i havent touched the reservoir..
Old Oct 20, 2003 | 10:09 PM
scrambo's Avatar
I'm knocking on wood but I'm 250lbs and havn't had any problems with my 03 scrammy's rear spring yet! I have jumped a few 4 and 5 foot jumps.
Old Oct 20, 2003 | 10:22 PM
hotseatperformancefan's Avatar
hey listen if mine didnt brake then no polaris should. i was in pennsylvania this summer and i went ridin at the traxx motorsports track. the jumps were HUGE like 10- 15 feet. i was hittin them and clearin the doubles and everything and no problems. maybe u just got a lemon!?!? o yea i way 135 pounds though[img]i/expressions/face-icon-small-frown.gif[/img]
Old Oct 24, 2003 | 03:48 PM
Scrmblerman's Avatar
No problems here. But I don't jump much. Sorry to hear your having problems.
Old Oct 24, 2003 | 08:26 PM
fishslab's Avatar
I'm 240 lbs and I love to jump my Scrammy and have had no problems. I think you've got your spring way to tight for your weight. I'm only about a third up the threads on mine. If I were lighter I would need less tension than that. Next maybe your gettin too much weight on the rear when landing. Just my guess though. Let the spring out all the way, find out where it wants to bottom out at and put some tension on it. You just want to barely keep it from bottoming out on the big jumps and thats all.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 8, 2015 06:13 AM
