blaster electrical help
Old Oct 20, 2003 | 11:43 PM
blasterboy1086's Avatar
Default blaster electrical help
i have a 2001 blaste and i added some lights to it but they dont run because the stator dont put out enough power ...what should i do ..could i put a small atv battery on it ...does anyone know how much the stator puts out ..hopfully someone can help im sort of lost...thank
Old Oct 21, 2003 | 10:38 AM
sAyIt_fmf's Avatar
when you say they don't run? at all? what wattage are they?
Old Oct 21, 2003 | 05:07 PM
yeah they run but not bright enough to do any good ......there is two of them they have 55 watt bulbs ......would i be able to put a battery on it
Old Oct 27, 2003 | 05:24 PM
can somone help
Old Oct 27, 2003 | 05:40 PM
sAyIt_fmf's Avatar
"You Added some lights" ? Two? How are they wired? In series or parallel? Wire them in parallel for starters...also remember that with the blaster...the lights will only come on and get bright as the engine speed increases...
Twin 55watt fixtures is a bit overkill for a blaster stator...but you should get some light out of them...IF not...try one light and go up from there.
I can't even remember what was on my blaster stock 35 watts?
Old Oct 27, 2003 | 06:40 PM
BLASTERDEVIL2's Avatar
wattage is to high for a blaster. run two 25 watt bulbs and it lights up good or try one 55 watt.
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
