better carb for sp600
Old Oct 21, 2003 | 01:30 AM
DANO38's Avatar
Default better carb for sp600
Has anyone found a better Direct Replacement carb for the sp600's???? I'm getting sick and tires of sticking slide,
plugged/stuck jet, and intermittant no idle problems I've had with mine since it was new!!!!!!!!!!!!!!!
Old Oct 22, 2003 | 09:01 PM
Festis's Avatar
I have a 2003 700. and put the heat seat header and pipe on and a flat side carb 38mm and clutch kit.
And now it's a bike.
38 MM TMX - Sportsman 700 and 600
The 38 TMX flatslide carb flows 30% more than the stock 34 CV carb. Get 3 HP, instant throttle response and quick acceleration.
600/700 Sportsman Super Header A 5-6 peak horsepower gain will give a noticeable increase in power for trail riding or mudding.
EPI Clutch Kit.
Old Oct 25, 2003 | 12:19 AM
markie's Avatar
If there's any slack on your thumb throttle your bike will Idle bad and die,the adjustment Is on the cable on the handle bars, make It so theres no slack on the thumb throttle
My machine Is getting counter weight installed for the trans today I'll let you know If It helps and getting jetted for high alt they say It makes a big dif.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
