DS backfire
Old Oct 24, 2003 | 06:33 PM
crazypainter's Avatar
Default DS backfire
Have an 03 bone stock DS which ive had for about 2 months I dearly love it but it has a quiurk that my dealer hasnt heard of. It backfires and stalls . You can feel the pop under the seat , it always starts right back up. it happens intermittantly. sometimes after iIve been raceing it sometimes tooling down a trail in sightseeing mode. the plugs were replaced ,good fuel put in no difference. It doesnt happen every time I ride it eve but it does concern me. Any thoughts? Thanks.
Old Oct 24, 2003 | 07:00 PM
ScoobyDFW's Avatar
Default DS backfire
intake valve clearance too tight?
Old Oct 24, 2003 | 07:05 PM
dsdrew's Avatar
Default DS backfire
My 02' Baja does it once and a while. Usally when im racing or running it hard. Never backfires hard enough to stall it though.
Old Oct 24, 2003 | 07:22 PM
Default DS backfire
if the valves were too tight wouldnt it backfire more frequently?
Old Oct 24, 2003 | 07:40 PM
RoughRider01's Avatar
Default DS backfire
Mine used to do that when the temps dropped down. It would backfire out the carb and sometimes stall. It usually happened when letting off the throttle after running at higher RPM's. It even did that after the valves were adjusted. Sounds like its running a little lean. You can richen up the air/fuel screw and add a bigger main jet to see if that helps.
RoughRider01
Old Oct 27, 2003 | 02:22 AM
IBlameTheDog's Avatar
Default DS backfire
My Predator does this too but just every once in a blue moon. I know that this is a different quad but it shares a lot of similar features like the carb is identical and the airbox setup is similar. Maybe it is a carb issue???? I don't think that it is causing any damage.
Old Oct 27, 2003 | 02:13 PM
Default DS backfire
itook it out sat. am and rode - it popped once. came home set it up according to MRHP's setting took it out sunday for 5 hours and not a pop once. Plus got to spank a piped and jetted Raptor Seems it was running a little lean. Thanks to everyone that responded.
Old Oct 29, 2003 | 02:43 AM
marrtoo's Avatar
Default DS backfire
ALWAYS REMEMBER if you smoked as many things as the DS then you would probably cough every once in a while too.[img]i/expressions/face-icon-small-smile.gif[/img]
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
