03' 400 auto, How much diff fluid? What kind?
Old Oct 24, 2003 | 10:04 PM
want2Bmuddy's Avatar
Default 03' 400 auto, How much diff fluid? What kind?
The owners manual says that the diff should be filled about one inch below the fill hole. Is this correct? Can I remove the conventional oil and replace it with synthetic? What kind would you recommend? I thought the fluid level should be at the base of the fill hole? Thanks for your reply!
Old Oct 24, 2003 | 10:43 PM
BigCatDriver's Avatar
mine is a bout 1-1.5" below the hole, I needs that space for air I think, I also run Lucas and nothing else. I have ran it in diffs for years. the only problem is that it is expensive, so if you have to change your gear oil often due to water in it. It will cost more.
Old Oct 25, 2003 | 10:06 AM
honda450es4x4's Avatar
how do u know if u have water in your diff fluid
Old Oct 25, 2003 | 10:11 AM
its kinda hard on an ATV because the diffs are so small so i just change mine often if I have been in the water which I always am. But in jeeps you can see it, the fluid starts to look milky, Its just a good Idea to change the fluid on a regular basis, and besides the gear is not that expensive, not even the synthetic
hueby
Nov 6, 2015 11:34 AM
Clint Russell
Sep 25, 2015 03:20 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
John Reed
Sep 9, 2015 03:46 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
