Possible cause for miss just of ideal
Old Oct 25, 2003 | 01:44 AM
arnold's Avatar
Default Possible cause for miss just of ideal
I found this info in a may isue.
just went thru that issue with mine. I even took mine to an authorized dealer who jetted the bike and adjusted the carb but did not fix the problem. The problem is a loose wire on the ignition coil. The ignition coil is mounted uder the tank and the wire can been seen from the left side slightly above the rev limiter. It is a black wire and the bike will start once off but tends to act up when lightly pressing the throttle. I discovered this while installing an RPM gauge on the bike. The coils needs to be tapped in on the installation at which time I discovered the loose wire. If you cant find the wire contact RON WOODS and ask them to fax you a copy of the installation sheet for the RPM Gauge and you will find it. Good Luck, Joseph Oceguera E-mail Joemiami07@aol.com 00 DS 650 Custom X Muffler Rotax Box K& N Filter Carb. Jetting Alba Racing Kit Nurf Bars RPM Undercarrige Protection 6 Pack Rack Ron woods RPM Gauge
95wolv
Sep 27, 2024 12:00 PM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
tysonbully
Sep 28, 2015 02:30 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
