mods for quicker revving and a harder hitting powerband
would raising the exhaust ports result in quicker revving? and what are some things I can do for a harder hitting powerband? lighten the flywheel maybe? thanks
I do not believe raising the exhaust port will do that for a blaster. When you do that you increase lift in port timing but loose compression at the same time. It would rev. a higher rpm but not faster revs.
With all the mods. you have I would install a Vito's 4 degree advance key and Vito's jet kit for the carb.
Sep 23, 2015 06:23 AM
