Cooling Fan
Old Oct 30, 2003 | 12:32 AM
NicktashCowboy's Avatar
Default Cooling Fan
I just bought a 2000 500 cc Cat. The fan comes on as soon as I turn the key on. The guy told me that all Arctic Cat do that, but now I know that was bull. Anyone know what the problem could be and how to fix it?
Old Oct 30, 2003 | 12:51 AM
ZukiRacr250's Avatar
Default Cooling Fan
What you may have is an overide switch someone has installed.
Or you could have a bad cooling temp switch.
If it is the switch you can test it by un-hooking the connectors and applying a 12volt source to the switch when the motor is cold, if you recieve a 12 volt signal from the other wire coming out of the switch, then you need a new switch!
hope this helps!
Old Oct 30, 2003 | 03:13 AM
Castr8r's Avatar
Default Cooling Fan
NicktashCowboy-
I bought my 2000 Arctic Cat new and the fan always comes on when the ignition switch is turned on. If it doesn't, then you probably have a blown fuse- especially if you've been running deep water. Later model 'Cats went to a thermostatic type control that turns on the fan at a preset temp. Hope this helps.
Old Oct 30, 2003 | 09:29 AM
TORK's Avatar
Default Cooling Fan
Check lower left corner of radiator for temp switch. most cats have one but one year to year and a half they tried running full time and then went back to switch. Yours is probabley OK.
Old Oct 30, 2003 | 04:43 PM
gltco's Avatar
Default Cooling Fan
In 2000 thats how they came from the factory. Previous years had a sensor to control the fan but that gave a lot of trouble so in2000 they did away with it. You can add a switch to the power wire so you can turn off the fan when in water etc. Later models have a sensor that works not bad that you could install also.
Old Oct 31, 2003 | 06:31 PM
BigCatDriver's Avatar
Default Cooling Fan
he is right the 2000 500 Fan runs all the time, never given me any problem in the water even if I dont turn it off
Old Oct 31, 2003 | 09:31 PM
Default Cooling Fan
Thanks everyone for the information. I got the answer faster from this site than my local dealer.
The fan is on all the time.
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
alzgarvin
Sep 11, 2015 08:53 AM
lancemll88
Sep 5, 2015 03:16 AM
