does that radiotor fan do anything?
Old Oct 30, 2003 | 11:20 PM
Aminal's Avatar
Default does that radiotor fan do anything?
Old Oct 30, 2003 | 11:21 PM
Aminal's Avatar
I have a 400 sport, and that radiotor fan is the only thing holding me back from takin off my battery, does it really do anything?
Old Oct 31, 2003 | 12:57 AM
RookWV's Avatar
It keeps things cool when you're not going fast.....boiling your radiator isn't a good thing...
Old Oct 31, 2003 | 01:03 AM
trailrider500's Avatar
Would you take the fan off your car? You have got to keep it on their when you are not moving fast the engine runs hot the cooler you keep your engine the longer the top end will last...
Old Oct 31, 2003 | 01:37 AM
Traildog's Avatar
Polaris designs there cooling systems to be fan assisted. That means if you don't have an operating cooling fan your engine will overheat, period. The bottom line is you need the fan.
Old Oct 31, 2003 | 01:41 AM
fishslab's Avatar
You should be able to run fan and lights without the battery. As far as I know the fans shut off when the quad is turned off. You may need a different voltage regulator, but they are only about $20.
Old Oct 31, 2003 | 01:44 AM
BigBadScrambler's Avatar
White Bros. makes a battery eliminator kit. I am not sure what all it intales but it may address the fan issue. If all you do is go in a straight line for a minute and nothing else, then you MAY be able to get away without a battery, but you will have to run Enghine Ice and probably radiator scoops as well. I wouldn't recommend it though. Also, if you don't have the battery eliminator kit and run it without the battery, the voltage spike with blowout your lights and some fuses
Old Oct 31, 2003 | 09:25 AM
CED's Avatar
CED
I have been running mine without the battery for over 2 years.I installed the battery eliminator from white brothers.And my fan has been removed for 2 years also.I run engine ice and never had any problems with overheating.Hope this helps.
Old Oct 31, 2003 | 10:39 AM
modquad's Avatar
To go with CED and Big bad. As long as a coolant additive (Redline's Water Wetter is my fave) is used, these 400's run pretty cool. I would suggest using an HPD billet head also. The eliminator kit is just a jumbo capacitor. You can still run lights, or other gear when the machine is running. You can also step up to a modded stator from Ricky Stator.
Old Oct 31, 2003 | 12:14 PM
dunerdogg's Avatar
I have been running my 400 sport without the fan for about a year naw and I have not had any problems yet. you just got to have air going through your bike (when your riding) you just cant burn it up or you are screwed!!!
