HELP! with adjusting chain on 2003 warrior
Old Oct 31, 2003 | 06:05 PM
2003warriorblackandred's Avatar
Default HELP! with adjusting chain on 2003 warrior
I just replaced the front sprocket from a 13 to a 12 on my 2003 warrior. Now the chain was wicked loose so I removed a link but i'm having trouble with getting the axle to move forward. Any help will be greatly appreciated!
Old Oct 31, 2003 | 06:18 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
it tells how i nthe owners manual
Old Oct 31, 2003 | 06:32 PM
I'm sure it does but I don't have one right now!
Old Oct 31, 2003 | 06:37 PM
HoundDog06's Avatar
You want the axle to move forward? Just tighten the tensioner bolts sticking out from the rear axle bearing carrier. Don't forget to loosten the carrier nuts and the tensioner jam nuts.
~HoundDog
Old Oct 31, 2003 | 06:38 PM
Kintama's Avatar
You need to loosen the bolts on the axle, and then tighten with the adjusting screws. Make sure that you are not to much to the right or left. You need to be pretty straight.
Old Oct 31, 2003 | 06:40 PM
trailride's Avatar
WHY DID YOU REMOVE A LINK ? I PUT A 12 TOTH ON MINE AND I JUST ADJUSTED IT BACK. THE WAY YOU ADJUST IT IS ON THE BOTTOM OF YOUR AXLE BELOW YOUR REAR SPROCKET IS A BOST THAT FACES YOUR RIGHT REAR TIRE LOOSEN IT AND THEN THERE IS A BOLT FACING YOU AS YOU ARE LOOKING AT THE REAR OF THE BIKE TURN IT IN AND WATCH YOUR CHAIN . YOU WILL NOTICE MARKS ON THE SLIDE TO INDICATE WHEN TO CHANGE YOUR CHAIN. BE SURE TO SIT ON IT OR PUSH DOWN HARD ON THE GRAB BAR TO TAKE SLACK OUT TO SEE THAT ITS NOT TOO TIGHT. WHEN YOUR THERE JUST TIGHTEN IT BACK AND YOUR DONE.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 31, 2003 | 06:42 PM
trailride's Avatar
OOPS YOU SAID FOWARD. KICK THE CRAP OUT OF IT (LOL).
Old Oct 31, 2003 | 06:47 PM
Diablo's Avatar
Sounds like you need to put the link back in then use the adjustments to get rid of the slack.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
95wolv
Jul 17, 2015 08:13 PM
