Blaster, Are they Junk?
Old Nov 2, 2003 | 08:34 PM
thebutelr's Avatar
Default Blaster, Are they Junk?
I'm wonderin if a blaster is junk or are they good bikes, the reason is because i'm thinkin about buyin a 94 blaster for $800 that needs new rings put in it. I've always heard that they are junk and they blow up all the time cuz of their oil injectors. Someone please help me with this. Thanks.
Old Nov 2, 2003 | 09:34 PM
ShadyRascal's Avatar
Blasters are good machines. I have a couple for my kids. The oil injection works fine. They are simple and reliable, and easy to work on. All models up to 2003 have mechanical rather than hydraulic brakes, which aren't the greatest, but they work. Have no fear, get that one, and the aftermarket is big too.
Old Nov 2, 2003 | 09:40 PM
thebutelr's Avatar
Really? Are u sure that if i get it i should leave the oil injectors or get a block kit for it? And also are you positive that they don't blow up after u just ride them around for a week? Please relpy asap. Thanks.
Old Nov 2, 2003 | 10:08 PM
Hozed's Avatar
no quad will blow up every week
id get the block off's, id rather mix my own gas that way you know its right.
Old Nov 2, 2003 | 10:17 PM
thebutelr's Avatar
Ok, just makin sure cuz my friend bought a brand new blaster and the motor blew up the first week he had it cuz the stupid oil injectors stopped workin and the piston siezed.
Old Nov 2, 2003 | 10:22 PM
ZBlaster's Avatar
ive never had a major problem with my '94. get the block off kit because sometimes the injectors do mess up. if it only needs rings i would get it.
Old Nov 2, 2003 | 10:26 PM
Starky's Avatar
The Blaster is a good quad, that's why they've sold a kazillion of them. Mix your own gas if you don't trust the injectors. For the guy who's brand new quad blew up, that's why they have warentys
Old Nov 2, 2003 | 10:32 PM
thebutelr's Avatar
Ok, are rings hard to put in a blaster engine? I've never opened up a quad engine before or even any engine for that matter. I think i'm gonna have to get a service manual or have someone at my local yamaha dealership do it for me if i get the quad.
Old Nov 2, 2003 | 10:46 PM
BeerSmurf's Avatar
Top end on the Blaster is as easy as it gets.
I would send the cylinder off to a reputable shop and let them check it and machine as needed.
Then let them provide you with the proper piston.
Buy the Yamaha Manual it is good.
You may want to read
http://www.macdizzy.com/1989hopup.htm
Have fun
Old Nov 3, 2003 | 01:31 AM
yfsrider's Avatar
you know what? your friend sounds like an idiot, did he put oil in the injector? DERRRRRRR
