Stock clutching info on Sp600
Old Nov 3, 2003 | 01:20 PM
BuddyP's Avatar
Default Stock clutching info on Sp600
Looking for the following info:
Primary spring color and weight (initial and final)
Secondary spring color and weight (initial and final)
Primary clutch weights
Secondary helix angles
also jetting specs (main & pilot)
Thanks
Buddy P
Old Nov 3, 2003 | 02:27 PM
pest44's Avatar
I have the info at home in service manual. I'll post it this evening if no one else has.
Old Nov 3, 2003 | 03:11 PM
lovemud's Avatar
The stock springs are blue/green primary, white secondary, weights are 50.5. If you do a search you'll find the spring weights posted.
Old Nov 3, 2003 | 06:41 PM
pest44's Avatar
According to Polaris service manual RE: 2003 600
Main jet: 155
Pilot jet: 45
Pilot air jet: 160
Primary spring: blue/green
Secondary spring: White/yellow
Clutch weihts: 10 MH (50.5 gr) (0-6,000 ft) should be what's stock
10 WH (46 gr) (6,000-12,000 ft)
Old Nov 3, 2003 | 07:24 PM
BuddyP's Avatar
Thanks a bunch!!!
Do you have any idea what the lb rate of the primary and secondary springs are?
How about the converter helix angles?
Old Nov 3, 2003 | 08:44 PM
pest44's Avatar
According to the graph ( if I'm reading it correctly), the blue/green is about 130 pounds at full upshift and 18 pounds in neutral and it goes down in between the two. I don't see anything for the secondary force. It only shows the different ones available. You might could find out Here.
slowgsxr97
Mar 18, 2022 03:40 AM
STLyamwar
Jul 25, 2020 04:44 AM
ghost civic
Jan 15, 2020 07:43 AM
GearheadMOM
STOLEN
Aug 8, 2015 11:47 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
