Top speed on a scrambler 500 4x4
Old Nov 3, 2003 | 08:21 PM
trailrider500's Avatar
Default Top speed on a scrambler 500 4x4
I was wondering how fast my scrambler 500 4x4 will go with the mods i have listed below? i think it will go like 65-68
Also how hard is it to install a trail tech speedo?
And dose anyone have any tips on geting so more speed out of it...
Thanks
Trailrider
Old Nov 3, 2003 | 09:11 PM
RookWV's Avatar
Probably 65 or so...Trail Tech's are a snap to install...Mount the holder, run the cable to the front rotor, drill a hole, mount the snesor, glue a magnet on the disc----Done!
One of the biggest things to help out is reduce the weight....but it's also a hard thing to do because the 4wd system is what really adds the pounds....
Old Nov 3, 2003 | 09:30 PM
Thanks Rook since you have a speedo is 65 or so, a guess or have you toped out your scrammy yet?
Old Nov 4, 2003 | 12:22 AM
RookWV's Avatar
I haven't topped it out yet, haven't found any place long enough to do that....it's more a guess...I did get mine up over 55 and it was still pulling....those things aren't a whole lot of fun going that fast....
Old Nov 4, 2003 | 12:24 AM
Yeah i know what you mean, Thanks Rook for your input!
Old Nov 4, 2003 | 12:31 AM
BigBadScrambler's Avatar
I would estimate around 65. I had mine to about 62 when it was stock. I have a mad vibration around 40mph so I haven't taken it faster than that since the mods. This winter I am getting aluminum rims ( I believe that some Slime solidified in one of my tires causeing the vibration) so I will be able to see what she does this spring
Old Nov 4, 2003 | 12:35 AM
Thanks Big Bad cant wait to see what it tops out at, Hopfuly i will get a trail tech for x-mas!
Old Nov 4, 2003 | 12:53 AM
A Trailtech is a great little unit.They are developing one with a hookup to the battery so that you can have the "nightlight" on at all times if you want. They are also making one with a Tach on it too. Should be interesting to see what they come up with. PM me when you get it and I will give you the numbers to program in it for tire size (assuming you still have 23's on the front). Later
Old Nov 4, 2003 | 12:54 AM
Were you able to find that shift ****?
Old Nov 4, 2003 | 06:08 PM
Yeah i got the shift ****, Also i still got the 23s on the front....
