KFX 400 R4 pipe-----Jetting Required???
Old Nov 4, 2003 | 04:40 PM
crazicooter's Avatar
Default KFX 400 R4 pipe-----Jetting Required???
I just put a R4 pipe on the KAWI and it seems to run great, sounds great. Any idea if I need to jet it?
Old Nov 5, 2003 | 05:58 AM
cartman308's Avatar
pull the plug.........if it's tannish you are lean and need to go up as size or maybe two. If it's black (more than likely not) you are rich and need to get more ait in the motor. You are more than likely lean. Running lean isn't recommended. It can cause SERIOUS motor damage!!!!!
good luck
Old Nov 5, 2003 | 10:35 AM
jeffksf3's Avatar
Yes, I agree with Cartman, and make sure you open up that airbox to get the most out of that pipe.
Old Nov 5, 2003 | 12:32 PM
Thanks guys for ideas, I will pull the plug tonight. One more question--- How much time should I put on it before checking the plug? I just put the pipe on 2 days ago and haven't been on the bike for more than a 1/2 hour.
BYC
Sep 25, 2015 02:10 PM
cboler9
Sep 24, 2015 08:35 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Elkaholic
Sep 6, 2015 02:44 PM
Haakon
Aug 24, 2015 01:54 PM
