trailblazer 250 problem
Old Nov 4, 2003 | 10:00 PM
simster570's Avatar
Default trailblazer 250 problem
Hy I have a stock 2000 Trailblazer 250, and I have noticed that if you give it full gas from a compleat stop, it revs up then after about a second or two, it starts to take off, very slowly at first, but then it gets back to normal. It seems like its better just to gradually give it gas at takeoff. Is this normal or is there a problem? Is there a way to fix it or will I need some mods? Also, it seems my that it is burning fuel kinda rich(smokes a little) is this normal or is there a way to fix it?
Old Nov 4, 2003 | 10:48 PM
JWtrailblazer250's Avatar
Sounds like your belt is sliping,I would get it checked out.Mine smokes a little when its cold.
Old Nov 4, 2003 | 10:53 PM
Quadman500HO's Avatar
If you have not replaced the belt, that's the problem. As the belt wears it reduces in width, riding lower in the clutch shives. In addition, it gets slick and just won't grab. Replace the belt and don't forget to do the rubber seal gasket around the shroud or you'll fill that compartment with water in the first stream.
Good Luck,
Gene
Old Nov 4, 2003 | 11:56 PM
Trailblazer250exrexr's Avatar
IF UR GOING TO GET A BELT DO NOT GET 1 FROM POLARIS GET IT FROM HPD THEY LAST LONGER
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
