Lt50a Wont Idle
Old Nov 5, 2003 | 08:01 PM
Smitty1's Avatar
Default Lt50a Wont Idle
Help!!! I did some of the upgrades on the lt50a like remove the restrictors in the exhaust and intake, and I drilled some holes in the airbox. But now the quad wont idle and is hard to start. It does have lots of power now. I did not do any carb work, like removing the top jet and or replacing the main jet. Does anyone know if this has to be done and do you think this is why it wont Idle. Thanks Mike
Old Nov 6, 2003 | 12:19 AM
MattFisher's Avatar
You added air, but now you need to add fuel, that's where the jetting comes in.
Start with removing the stacked pilot jet, you may also need to adjust the needle height and the air screw.
It's likely that using the choke will help it start right now, as that adds a bunch of fuel. That's a quick test to see if it's too lean.
Old Nov 6, 2003 | 12:24 AM
Smitty1's Avatar
Thanks I wil try to do that this weekend and post a reply here with the results. Thanks Mike
Old Nov 22, 2004 | 06:52 AM
nicks3's Avatar
where is the restrictor in the intake?
wrencher82
Sep 30, 2015 04:27 AM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
