removing lt 50 restrictions;please help
Can any one tell me how to remove the intake and exhaust restirictions on a 2002 suzuki lt 50?Is this a good idea and how will this benifit my kid's quad? Thanks for the input.
Crazy dad ...
The exhaust restrictor is between the pipe and the head. just remove the 2 screws that hold the pipe on and you will find a little washer. Just take it out and that is step # 1!!! The second restrictor is located between the carb and the little curved tube. Just remove that piece and remove the restrictor. It is seated pretty well in there and has a "slice type " hole that you can put a flat head screwdriver through to jar it loose. You will most likely have to heat it up to get it to come out. I actually used a fire stater to heat it up and it worked !!! Good luck .... It is actually very easy !!!!
THen your next step will be to get a pipe from DG for it !!!! You might want to get on their waiting list because they only make 10-20 of these pipes a year and there is a long waiting list ;-)
Good Luck,
Webb
Good Luck,
Webb
02, 2002, 2004, 50, exaust, good, governor, intake, lt, lt50, pipe, remove, restricted, restrictions, restrictor, restrictors, suzuki
