tb 250 chain
Old Nov 10, 2003 | 06:35 PM
simster570's Avatar
Default tb 250 chain
My chain on my tb 250 is loose...how do I tighten it?
Old Nov 10, 2003 | 07:04 PM
BigBadScrambler's Avatar
1. Loosen your chain gaurd.
2. Loosen the 2 eccentric bolts on the axel housing
3. Loosen the rear brake caliper mounting bracket bolts
4. Use a 2 1/2" wrench (or a big pair of channel locks) to rotate the housing to adjust the chain slack to have 3/16"-3/8" deflection. OR Insert a pin punch through the sprocket hub and into the eccentric axel housing. Roll the quad back or forth to adjust the the chain slack.
5. Tighten the eccentric bolts to 40 Ft. Lbs (if you have a hitch) or 30 ft. lbs (without a hitch)
6. Double check you chain deflection.
7. Tighten the brake caliper mounting bracket to 10-12 ft lbs
8. Reinstall or retighten chain gaurd to allow 1/8" clearance between sprocket and guide
And thats it
Old Nov 10, 2003 | 07:12 PM
simster570's Avatar
wow i didnt think it was that complicated....but ill try. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 10, 2003 | 07:22 PM
Its really not that bad. Just loosen a few bolts, rotate the housing until the chain is in specs, the torque the bolts. In a nut shell[img]i/expressions/face-icon-small-wink.gif[/img]
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
