Shifting
Old Nov 11, 2003 | 07:28 PM
highwayman's Avatar
Default Shifting
I have a 99 335 SP with 1700 miles on it and I am having a small proublem shifting when I push the lever ahead to go in gear nothing happens (reverse too) if I rev the engine a little bit it clicks in. Should I turn the idle up a little or do I have to make some adjustments to linkage?
Old Nov 11, 2003 | 07:52 PM
Polaris500HO4x4's Avatar
Default Shifting
how is your clutch? have you ever had your clutch looked at it might be the problem too or u could be right you might need to idle it up a little bit
Old Nov 11, 2003 | 08:30 PM
BigBadScrambler's Avatar
Default Shifting
Sounds like you need to adjust your linkage. The tie rods on the linkage could be worn out as well. Start with the simple stuff
Old Nov 11, 2003 | 08:31 PM
ftwflh's Avatar
Default Shifting
Try changing the oil in the shifter before doing any thing else.
Old Nov 11, 2003 | 11:59 PM
Default Shifting
hey ftwflh Pro Rider how exactly do you change your oil in the shifter i would like to know thanks
Old Nov 12, 2003 | 07:41 AM
ftwflh's Avatar
Default Shifting
To change the oil in the shifter you take the top off of the shifter(watch wheree the springs and ball go)most of the time it is dry.You may need to take the assymbly off and clean it real good before putting in new oil 10w40 . Some thing else to check is the alluminum shift levers on the tranny they get wore out and have play in them causing the bike not to go in gear all the way.
Old Nov 12, 2003 | 05:49 PM
Default Shifting
ill have to try that thanks
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
