K&N filter questions
Old Nov 13, 2003 | 12:18 AM
XxDumontRaptorxX's Avatar
Default K&N filter questions
Can I put 2 K&N's directly on the carbs and eliminate the airbox all together? Can I also put them on the pro flow adapter if not the carbs?
Old Nov 13, 2003 | 12:23 AM
sixsixT's Avatar
The carbs don't work as good without the tubes.
Old Nov 13, 2003 | 07:57 AM
Ward660R's Avatar
I don't think you could find any to fit right on the carbs, they are too close together. Plus there would be no place to hook up the vaccume line off the top of the carbs.
Yes you can IF you cut off the air box, and its not a pretty thing. I did mine like that because I wanted to run without an air box. At the time there was no other way to do it without fabbing some kind of bracket, now there is a much better option.
Old Nov 13, 2003 | 08:40 AM
I see no use for an airbox anyways.
Old Nov 13, 2003 | 02:40 PM
AlphaRaptor660R's Avatar
you should ask SixSixT for his adapter plate...
Old Nov 13, 2003 | 02:50 PM
Its allready been done [img]i/expressions/face-icon-small-wink.gif[/img]
Ronk407NY
Feb 13, 2016 11:05 AM
Jenn1
Sep 8, 2015 09:16 AM
QuadCity
Aug 13, 2015 12:58 PM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
