warrior rear shock ?
Old Nov 13, 2003 | 12:42 AM
trailride's Avatar
Default warrior rear shock ?
How do you make the warrior rear shock stiffer so when you sit on it it doesnt squat so much. my spring on the shock is adjusted how do i say it ----short or adjusted all the way up . is there anything i can do to make it even stiffer?
Old Nov 13, 2003 | 02:00 PM
NLWarrior01's Avatar
The only way I know to make it stiffer is to adjust the preload. I dont' recall if that's on the top or the bottom of the shock .. I believe it's on the top. What you want to do is screw that sucker all the way down, compressing the spring as much as possible. Other than that, the only other adjustment on the shock is the rebound, which controls how quickly or slowly the shock reacts to the terrain. If it's set too quick it will be very bouncy. If it's set too slow you'll end up with the condition of having your shock open when it should be closed and closed when it should be open!! Not good.
I like my rear shock soft cuz it makes for a nice smooth ride. takes the wrinkles out of the trail [img]i/expressions/face-icon-small-smile.gif[/img]
Bratman2
Aug 6, 2022 01:42 AM
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
